10.01.2006, 10:49 PM
Since he mentions the 51T spur, I will assume Mod1. If so, most setups using the 51T spur also use the strobe slipper setup. Unfortunately, that slipper is almost impossible to come by. You may be able to use other slipper setups though and I'm sure someone else will chime in.
