Finnster
KillaHurtz
Finnster's Avatar
10.10.2006, 05:49 PM
Originally Posted by mrsoundman
Interesting you brought that up. 2 days after I purchased the $280 quark, I was reading about the Mamba Max on 4s in a truggy. I may end up throwing my Mamba Max controller out of my T4 into this truggy and use the Quark in my future MGT conversion w/ a Neu Motor.
I'd have to dream up some interesting way to mount a 40mm or bigger fan above the Mamba Max blowing down onto it. I guess I could use some fuel tank standoff's and a larger center diff cover to mount a large fan above the ESC.. Hmmmmmm.....
I used 1.25" alu 4/40 standoffs to mount a 40mm fan above my MMax on an earlier version of my ERevo. I simply drilled and taped a hole w/ 4/40 threads in the 40mm pattern in the esc mount, then just use 4/40 screws thru the fans into the standoffs. Really easy to do and covers the entire esc, snugly on the sides. The fan then blows down on the caps as well, which is a bonus.
I've been working on cleaning the layout up (something you did very well, congrats) and the esc has moved and has a smaller 25mm fan which is working well.
Very nice job and its good to see and hear about your conversion. I am glad you are liking the Neu and it is staying so cool. I am sorry to hear about the spektrum rx still having int probs tho. I was thinking about going to one of these hoping I could move my rx around and rid some of the glitching I get at distance. Maybe won't work like I'd hope tho.
Lastly, what grade alu is the mount? No chance of it bending or flexing?
Awesome job and happy racing. Post a vid if you can!
