vette1
vette1
vette1's Avatar
10.16.2006, 07:17 AM
The only thing I can tell you is that they are holding up so far.
I can't wait to get the batteries, this thing is going to fly. :eek:
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
10.17.2006, 05:10 PM
You were having problems with your batteries heating up what was it?
How do you like your BK20150 controller your the first person I've seen with one.
BTW NICE TRUCK you did a very good job on it.
Never fight an ugly man..... he has nothing to loose
vette1
vette1
vette1's Avatar
Thumbs up 10.17.2006, 06:58 PM
Thank you for the compliment. It took about 6 weeks before getting it right.
I changed the rear body mount to Integy with black plastic post to see if it is stronger then the Trinity mount. So far holding up. :027:
As far as the battery problem it turns out it was the batteries shorting out against the chassis. :mad:1 I ordered from Mike new blue cussions for the batteries and I shrink wrapped all my batteries instead of some of them. I also replace the UBEC with a new one. I tried it out with two different runs on Sunday and I did not have any problems at all.
Now onto the BK20150 controller - what can I say but IT'S GREAT. I don't like the fact that it has two wires for each lead to the motor, (that makes a total of six.) It makes it difficult to solder two wires that thick to a deans connection and then add the bec wire to it also and then of course I needed to shrink wrap all of that. This was a royal pain in the but. However setting it up could not be easier and disabling the the bec was real simple. Performance and speed is not a problem either, it does what I want it to do immediately. However I had to put my speed controller braking down to 50% because it was stopping to hard. The sparks under the truck was the front of the chassis hitting the ground during hard braking at night. That is why I lowered it to 50%.
Heat is not a problem anymore. Since I been playing around trying to fix up all the problems I had, heat is no longer a problem. Sure it gets warm on the batts, eng. and the esc but not burning hot like it was. Thats why I have the 2-3S 8000MAH Maxamps lipos on order from Mike. Now that everything works perfectly its time to run it at full speed. :027:
P.S. I finally bought the Bushnell radar gun 10-1911. I found it online at a local wharehouse and I picked it up for $90.00 (no tax/no shipping.) I am going to try two high speed passes:
1) Two six packs of GP3300 batteries in series. :007:
2) Then 2-3S 8000MAH Maxamps lipos. :043:
I'm crazy and I'm not afraid to talk about it.
