A4DTM
10.23.2006, 10:03 PM
Originally Posted by squeeforever
Go for 2 TrueRC 5S1P 4000 mah packs...I JUST got my 3S2P packs in and they aren't light to say the least...But, definately worth the money..
so 80a/120a won't be too little? what if I decide to get a higher kv 1512, or a 1515 in the future? I'm still very cautious of over drawing the batteries.
squeeforever
squeeforever's Avatar
10.23.2006, 10:50 PM
I don't think it would be a problem...But I'm not positive...I guess it won't be though. I personally wouldn't worry about it...
jhautz
jhautz's Avatar
10.23.2006, 11:19 PM
Originally Posted by A4DTM
ok, so once again.. which cells are my best bet? that's the only step remaining on this car..
there's maxamps, truerc, and the evo-20 cells I'm looking at..
I think two TrueRC 5s2p 8000mah packs would be my best bet.. 160a/240a, and 16,000mah. that'd be about $375..
two EVO 3700mAh 5S1P packs would give me 148a/222a/370a and 7,400mah for $470
or two MaxAmps Lipoly 6000mah 5S2p.. 180a/240a, and 12,000mah for about $400
so looks like truerc's are the best bet?
That is way more battery than you need. You don't want to be hauling around that much weight if you are trying to go fast. Get the TrueRC 4000mah 5s1p packs like Squee suggested and run them parallel for 8000mah 5s2p. If you are really gonna spend that much on lipos in one shot get 2 sets of them. You can always strap them together and run them as a 16000mah pack like you wanted. But, you wont need to and then you will have 2 sets of batteries. one to run while the other is charging.
I run a 5s 8000mah setup from TrueRC in my Maxx and Revo and have never had an issue at all. As a matter of fact I can barley warm the packs up. Ive used a bunch of deferent motors also. Feigao 9XL, 8XL,9L Nue 1515 2.5D (1700kv) and one run on a 1512 2.5d (2000kv).
While you may want to run a slightly hotter motor than these in your car, but it doesn't weigh as much as my 11+ lb revo so your amp draw should still be fine.
A 8000mah setup from TrueRC will be perfect. They might not be the best cells available, but for the money they are really hard to beat. I just got a 3rd set a couple weeks ago when they came back into stock. The latest set I got are a really nice build quality. They look really nice and are put together really solid. Dan over there must have been practicing.:018:
to make it...
or break it...
Silent...But Deadly
squeeforever
10.23.2006, 11:22 PM
Yup. I can say the same. I just got mine in today and they are put together GREAT!
A4DTM
10.23.2006, 11:42 PM
I've got a 1512/2.5d in the car right now, so i'm glad to to know that it's a tested setup. sounds like a plan, thank's again guys.
*edit, can someone post the specs of the batteries, so i buy the right ones.. truerc's site is making me dizzy.. are you talking about these?
Custom built TrueRC 18.5V 5S1P 4000mAh IN STOCK
Size
27mm x 50mm x 145mm
(1.06in x 1.96in x 5.7in)
Weight
Aprox 15oz / 425g
Discharge
Up to 40A Continuous
60A Max burst
Price
$90 IN STOCK
*edit, I think I got it.
jhautz
jhautz's Avatar
10.23.2006, 11:51 PM
That motor is sick on 5s. I love it. I bought it for a project I am building now, but had to toss it in the revo over the weekend and give it a run. You will be able to gear that thing up and make that car of yours scream. My fat revo didn't even make it flinch.
to make it...
or break it...
Silent...But Deadly
A4DTM
10.24.2006, 12:26 AM
that's a part of my problem.. i can't gear up without getting custom pinions made.. right now, everything's been running real cool, so I think it should be geared up more, but can't.. Mike did mention making custom pinions, but I don't know what size would work best. 30/45 ratio possible? i have no idea :032:
jhautz
jhautz's Avatar
10.24.2006, 01:37 AM
Get your new batteries first. You will be tons faster with the lipos vs those nicd batteries. get some radar of your speed with the lipos and then go to brians speed calaulator on this site and enter your gear ratios, motor info, battery info and such and see if its pretty accurate. If it is, then just pick the speed you want to go and adjust the pinion size untill you get that speed on the calulator and thats the pinion you order.
If you are going for an insane speed run you will be way overgeared but you will just have to make a run or 2 and then stop and let everything cool down. Then try it again. You cant run consistantly that way, but you can put up some insane numbers that way.
to make it...
or break it...
Silent...But Deadly
glassdoctor
TEAM FUSION
glassdoctor's Avatar
10.24.2006, 09:51 AM
I don't think you need TWO of the 8000mah packs.... you mean total of 5s 16,000mah correct?
If so you can at least drop back to a 3p 12000mah pack. I have run that before in my truggy (4s3p 12000mah) and it holds voltage very well even at +100A spikes and hardly breaks a sweat at like 70A ballpark... that I'm guessing you will see on the track.
A4DTM
10.24.2006, 12:27 PM
j, I ordered two 5s1p 4000mah truerc packs, and two 505 balancers last night.
along with a hitec 5955 servo, and some female motor plugs, from Mike.
glass, how would you go about splitting 5s3p into two even packs?..
5s ok for short periods with a 540c-9l?
glassdoctor
TEAM FUSION
10.24.2006, 01:17 PM
You can't :) I thought of that when I typed it... but you are running oval right??
2s3p on right side, 3s3p on left.... of course you may not want to do that.
My gut says 2p would be enough. How much impact do you think the extra weight of a 4p would have?? More weight will help it stick to the track but at some point it will hurt accel out of the turns enough to not be worth it.
IMO 5s will be fine on the 9L
Hey what about a 6s?
jhautz
jhautz's Avatar
10.24.2006, 01:35 PM
Cool. Those packs will make a huge difference. (once you go Lipo... You never go back:018: )
5s on a 9L will get really hot... really fast. At least it did in my maxx.
to make it...
or break it...
Silent...But Deadly
A4DTM
10.24.2006, 02:02 PM
glass, no oval.. that was the reason for starting this project, but the track wouldn't let me run my rc.. so now i'm building for fun. racing, drags, ect..
no 6s because of quark's "6s problems"
j, the packs got hot? or the motor? think it might stand a chance in a 5lb car?
jhautz
jhautz's Avatar
10.24.2006, 02:20 PM
The motor gets hot. Its just the rpm that does it. On 5s you take it way past its peak effiency range and it just starts generating a ton of heat. Your right about the light car you might be better off than a truck. Shouldnt hurt to give it a try, just pay attenetion to the heats.
(Ive never had an issue with the truerc lipo packs getting anything more than slightly warm in any setup)
to make it...
or break it...
Silent...But Deadly
A4DTM
10.24.2006, 03:19 PM
sounds good.. i've run an old hacker b50 8S on 16cells before for ~6-8min at a time, w/ a hard driving style, so I figure a 9L shouldn't be a problem for short periods.
