Finnster
KillaHurtz
Finnster's Avatar
10.27.2006, 02:59 PM
Haha, couldn't resist. :)
Seriously tho...
I made a mount similar to what you need to make a mount for my rollbar.
Did you buy a 3mm tap? I just used a ~(1/4 or 3/8")x ~1" x whatever piece of plastic (some scrap UHMWPE from conv) trimmed to make an angled block (~same shape as Daf's alu piece.) I just then drilled and taped 3mm holes (dont have to tap, but its nicer/stronger) so I could run the servo screws thru. You could do a similar thing, but add retaining nuts to hold servo on.
Should be fairly easy. Alu is pretty and blingy; plastic is cheap, light and easy.
