Burnt Spur/Slipper Replacement Question
sracingcells
sracingcells's Avatar
Angry Burnt Spur/Slipper Replacement Question - 05.17.2005, 04:27 PM
I just went for the first run with my new feiago 8L and 9918 in e-maxx. It was making a squealing noise so i pulled it over and the spur gear was smoking! It has a hole burnt through it where the slipper is. I had it all the way tightened down(is that ok?)
So what I was wondering is what a good replacement would be for the spur gear and slipper. Should I get the dual disc slipper from robinson racing?
http://www2.towerhobbies.com/cgi-bin...?&I=LXBJB5&P=7
and what is this mod 1 pinion thing I hear about?
Thanks
BL E-Maxx
-Warrior 9918
-Feiago 8L
<a href="http://www.pics.schafferrc.com">Pictures
and Videos Here</a>
  Send a message via AIM to sracingcells
sracingcells
05.17.2005, 05:26 PM
Also here is some pictures of the spur
http://www.rcpics.net/member/SchafferRC
BL E-Maxx
-Warrior 9918
-Feiago 8L
and Videos Here</a>
HotnCold
HotnCold's Avatar
05.17.2005, 06:31 PM
Well I guess that is a first for me - i've never seen that before - i've seen melted gears but not the slipper burn thru - are you sure you had it completely tightened? - Wow -
Hows that "Hope and Change" working out for Ya???
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.17.2005, 07:08 PM
If your slipper was cranked down, then the slipper pegs were worn away. When I used the stock slipper, I used 12 pegs and cranked it for all she was worth. Never had a problem with this. The robinson slipper is OK, but it is a little inconsistent and the spur gears are a little soft. Ifg you want to upgrade slippers, I would go with a strobe, which uses mod 1 gears.
sracingcells
05.17.2005, 07:29 PM
I put a new spur on and tightened it down all the way and its running great now. It must have been loose when it happened. Thanks
BL E-Maxx
-Warrior 9918
-Feiago 8L
and Videos Here</a>
RC-Monster Mike
Site Owner
05.17.2005, 07:30 PM
Cool Glad your back up and running.
T2693
T2693's Avatar
05.17.2005, 10:55 PM
I had that happen to me with a stock 66t spur but I didn't know then to tighten the SOB... LOL..:cool:
  Send a message via Yahoo to T2693
HotnCold
HotnCold's Avatar
05.18.2005, 07:12 AM
Glad you figured it out - Still amazing that the spur could be burned thru like that - Says something about power - dosent it - LOL
