IBJAMMIN
IBJAMMIN's Avatar
10.31.2006, 11:30 AM
I built this car after the WFRCC contest but I will be there next year.:D
right now I have a Quark ESC with a Wraith 7000kv motor with a 4s 2100mah pack the front wing really helps keep it on the ground at high speed a problem Tony Phalen was having is the car going airborn above 70mph.
Yes I run the shocks upside down it helps keep the piston suspended in the fluid on bottom out and no leaks I also flipped the rear arms for 3/8" longer wheelbase and mounted the shocks in front of the axle.:)
