Serum
Serum's Avatar
05.22.2005, 03:31 AM
I think Mike can get you a set of batteries as well.
What do you want to run? 12 or 14 cells?
You don't need to go for the best of the best cells with the hvmaxx, the hvmaxx doesn't take too much current. (a good 30-55A max.)
nice hopups you've got in mind!
Did you considered the stock bulks aren't that strong? It is good to keep something a weak spot on your truck, but if you are going to aluminum arms, it very likely, that these will snap first.
