11.11.2006, 09:38 PM
That's exactly why I didn't go with a traditional electric stadium-truck setup. Just about all the common ones have the motor in the rear. The only logical choice then was to convert a Nitro one. Even with some of the weight in front of the rear axles you still burn up the tires. But at least you don't have the wheelie problem.
It's a whole other world driving the Jato vs the Revo on a track. On the Revo, I have to tap the brake or at the very least not accelerate on the corners, otherwise I have too much understeer (yes I know an RD quickturn or center diff would cure this). When I corner with the Jato, I actually increase the throttle so I drift around the corner. When executed right, it works very well - now only if I could do it all the time. If not done right, I just spin out. It takes a lot more finesse IMO with 2WD.
JB3231
JB3231's Avatar
11.12.2006, 01:46 AM
I thought you were going on road. The off road principles are different. I am seriously thinking about a 1/8th buggy with street tires and brushless setup.
FD has a setup already for sale. 53.1 MPH on a 4S battery. Think what it would do on 5S. This is really catching my interest.
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
11.12.2006, 01:58 AM
Yeah, I was going on-road, but I found it got a little old. There aren't any paved tracks that I know of around here and driving around by yourself isn't as fun as I thought it would be. It would be different if I had a 80+ mph vehicle, but the Jato aerodynamics are not meant for that level of speed.
After looking around a bit and asking some questions, I found there are pan cars that do have enough clearance to use in parking lots as long as the typical seams, cracks, and dirt aren't too bad.
No matter what, I like having the weight relatively centered in the truck.
