abiye
11.16.2006, 07:40 PM
looks awesome... what did you use to make the gears... is there a built in application within 2006 to build gears? or did you use something like geartrax?
jagboy
jagboy's Avatar
11.16.2006, 07:47 PM
I'm not sure how he did it, but in 2005 (probably many earlier versions as well, though I'm not sure) there is the toolbox that has a lot of premade gears. When I did mine I modeled the blank with an extruded circle. Then I opened the gear with the pitch and number of teeth I wanted and copied the 'tooth cut' sketch then pasted it on my blank. Cut extrude, circular repeat. Add extra modelling (cuts for cutting down on weight, slipper pad cuts) and you're done. There is probably a better way to do it, but this way is pretty easy.
JB
RC-NUT
RC-NUT's Avatar
11.16.2006, 08:17 PM
LOL
I cheated. First I extruded the inner diameter of the circle so I had a blank circle at the desired thickness. Then I measured the size of one tooth and created it on the same plane. Next I used my favorite command "pattern mirror" using the circular pattern. I used that command to create 55 teeth and checked off "equal spacing." The axis of the circle drove the command.
Make sense?
