crazyjr
crazyjr's Avatar
11.26.2006, 06:58 PM
I had a hv that seperated a magnet, it was not smooth either and its similar to the pletty, but not as many plates near the rotor and it also has the hard spots as does the pletty(though not as hard to turn). if the magnet has come loose it must have split for the shaft to roll free. If the magnet did not split and seperate, I'll have to agree with squee on it demagnetizing
marc993turbo
11.26.2006, 07:53 PM
... Can someone please explain to me why there are this hard spots on the pletti and why there aren´t any "hard spots" on a hacker or lehner?
Can someone _exactly_ explain the difference between the 2 and 4 pole engines? Or is there a website where it is explained in detail?
I only found this:
http://www.servomag.com/flash/4-pole/smi-motor007.htm
EDIT: I just saw the "Click here for written explanation" link on the page...
What about the burnt through coil?
If i turn the shaft i induce a flux within the coils - if one or more coils are burnt through there will be no flux and no hard spots ???
Is this totally nonsense?
If i pull the trigger the big maxx will turn slowly but you can easily hold the shaft with your fingers. Not enough power to turn.
Will shortly heating up the engine really demagnetize such strong magnets?
Marc.
squeeforever
squeeforever's Avatar
11.27.2006, 10:54 PM
It's quite possible if it gets hot enough...
crazyjr
crazyjr's Avatar
11.30.2006, 08:41 AM
Marc.
The Novaks and the Pletty's have their windings on an iron core (like an armature turned inside out), where others have the windings pressed in the can without the cores. where the iron cores come close to the rotor, it will attract the magnet and will want to stay when you turn, that's where the hard spot occurs.
The general consensus here is you never go beyond 200 degrees or massive demagnetizing will occur, Maybe not in a single run, but over time the magnets life will shorten. It's kind of like Lipo's, you can charge at 2 and maybe 3c and discharge at 20c constant, but due to their nature, it might shorten their life if taken to their max over a set time
