11.29.2006, 10:59 AM
Cheapest, as others have said, is to use stock chassis and tranny. The tranny will have to be modified if you want to use the motor for brake and reverse. Some chassis modifications may need to be made as well depending on your specific layout. As MM said, this means the batteries will be stacked on the right side. Be careful with weight distribution; once you decide on the motor, batteries, ESC, Rx, various mounts, etc you will use, sit down and figure out the placement for balance.
