jhautz
jhautz's Avatar
11.30.2006, 07:51 PM
Originally Posted by BrianG
I suppose you could waterproof it while you're there anyway. You'll have to use some material that won't weaken or get soft when substantial heat is applied, that won't get brittle after time, and can endure the vibrations and jarring. Maybe epoxy may be a better choice?
Shoe Goo ???
to make it...
or break it...
Silent...But Deadly
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.30.2006, 10:24 PM
I think Silicone would be perfect then, once it cures it's then almost the consistency of the silicone wire insulation (prob more flexible).
Also, are you sure you have to unsolder the motor wires? Can you not slide the top cover left off of it? Where exactly is the cap. near the esc button?
11.30.2006, 10:30 PM
jhautz: I tried Shoo-Goo on something else and it tends to get brittle and seperate from the thing it's trying to seal. I would think something flexible, yet heat/water/motion resistant would be better IMO as long as it bonds well.
I unsoldered the wire simply because it looked easier. You might be able to work the end off without unsoldering, I don't know. I guess you'll just have to try it. :)
The caps are on the power wire end (since that is where they are used).
zeropointbug
Z-Pinch racer
12.01.2006, 01:35 AM
BrianG, i tried taking the cover off without unsoldering the wires, i couldn't get it to come off. So i unsoldered the wires, and slid it off and noticed that the only thing stopping you from doing it the other way is the little see-threw plastic window for the LED's, it hits a little IC beside it.
Anyways, i go it all apart, except for taking it off the case. I notice that there is two alum. slabs one on both side of the bottom circuit board, and it looks like they are the same FET's ???!!! What!? Do you know if this is true? Or are they for something else? CHeck the pics, if they are the same FET's then maybe all they need is some heat spreading? And the thermal pad is just to attach to the case? It also doesn't really look like the pads are .5mm, they look thinner than that, maybe .3mm? I don't know... I don't want to take it apart yet, i don't have Thermal Adhesive at the moment, i'll pick up some Arctic Silver stuff when i can.
So is there two layers of FET's on the two sides of the power board?
Name:	DSC05719 (Small).JPG
ID:	2010   Click image for larger version
Name:	DSC05715 (Small).JPG
ID:	2011   Click image for larger version
Name:	DSC05717 (Small).JPG
Name:	DSC05713 (Small).JPG
