Originally Posted by MacII
I'd been using a bunch of Mod1 Pinions from Century Helicoptor Products. I've use the 9 tooth and the 46 spur. Also gone as high as the 12 tooth. I also did the LSP diff swap for the lower ratio.
The diameter of the Neu 1515 1y is wider than other motors and when I hold the motor in place, the smallest pinion I think I would be able to use with a 46T spur is a 11-12T otherwise the motor hits the center diff cup. The other option is use the 46T spur to adapt on a Ofna 51T spur. Or even have an adapter made. If I use a 51T there are a lot more gearing choices. I'm starting to think that would be the best option.
