zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.10.2006, 01:24 AM
Hey! Nice man! I have wanted to try an outrunner myself for a long time, i was up until a month ago, but decided to go 7XL... i was thinking about the E-Flite Power-46 motor, it's 670Kv motor, which should be able to drive a differential directly. It's rated for 55A burst, it had reversible shaft and everything.
That motor looks nice too, even though it's 65A, doesn't mean it won't perform! I here they perform in real world apps better than inrunner's of the same 'rated power' or peak amps. Are you sure you need a diff in there?? That seems like an awfully geared down setup, and i think it would be slow slow. What Kv motor is it?
zeropointbug
Z-Pinch racer
12.10.2006, 01:25 AM
BTW, how is everybody posting pics larger than 640x480? That's all i can do...
jhautz
jhautz's Avatar
12.10.2006, 01:33 AM
Originally Posted by zeropointbug
Hey! I have wanted to try an outrunner myself for a long time, i was up until a month ago, but decided to go 7XL... i was thinking about the E-Flite Power-46 motor, it's 670Kv motor, which should be able to drive a differential directly. It's rated for 55A burst, 800watts cont. it had reversible shaft and everything.
Its a 2093kv motor with a 40K rpm limit. They have some kind of diferent tecnology in it that they say it has all of the torque of a 10K outrunner, with 4 times the rpm so it has even more ''power'' than a conventional outrunner. Their cell limit is 16 or 5s for this motor. They claim that it is the highest power to weight ratio motor anywhere. I'm hoping that it does have the torque it claims so I can really play some games with the gearing. We'll see I guess.
You can read more about it www.cyclonbrushless.com
I use photobucket.com
to make it...
or break it...
Silent...But Deadly
