mtucker
Electron User
mtucker's Avatar
12.15.2006, 06:21 PM
Is it OK to use the Li-Saver with a car that is using reverse?
I ran into a problem with another brand of Li-Po cutoff device. Most are made for airplanes so when they do their "pulsing" they pulse down to near 0% throttle. 0% throttle on a car controller is full brake or full reverse if reverse is engaged. After coming to a complete stop it then went to full speed reverse. I really should have known better, but I guess the excitement of a new toy got to me.
Seeing a 8 pound buggy flying backwards down your driveway and into the iceplant at near 40MPH is quite alarming :026:
Perhaps the Li-Saver doesn't pulse below mid throttle (neutral for cars)?
Just thought I would bring this up.
Matt
neweuser
neweuser's Avatar
12.15.2006, 06:22 PM
Matt
the one that Mike sells will work good for you.
coolhandcountry
coolhandcountry's Avatar
12.15.2006, 06:26 PM
Matt
They have more than one version of the li saver.
It has a plane and car mode.
Mike sells the car mode one.
No worries on wide open reverse.
Peace!
Country
Help support the
Rc-Monster
Buy here
mtucker
Electron User
mtucker's Avatar
12.15.2006, 06:33 PM
That is good to know. Since I switched to the Mamba Max, I don't need a LVC any more (I run 4S).
I just wanted to make sure the same thing didn't happen to rustnpede in case the Li-saver did the same thing. He might not have as much iceplant as me :005:
Sounds like he is good to go.
Thanks,
Matt
rustnpede
RC-Monster Parking Attendant
rustnpede's Avatar
Thumbs up 12.16.2006, 04:55 AM
. . .I just wanted to make sure the same thing didn't happen to rustnpede in case the Li-saver did the same thing. He might not have as much iceplant as me :005: . . .
Thanks for looking out. No ice plant here just rocks, not so r/c friendly. Unless its a crawler:025:
