Procharged5.0
Procharged5.0's Avatar
12.21.2006, 07:05 PM
I don't doubt you. I've heard that the big bores were different.
Trinity HD Blue springs fit well and have a nice rate for the Emaxx.
neweuser
neweuser's Avatar
12.22.2006, 10:06 AM
What I did to make the springs fit snug, is I took the spring mount from the stock shock, trimmed the inside and fit it right around the Big Bore shock spring hold, I used the blue as well and they worked great. I just found that the UE shocks worked better for my needs.
Procharged5.0
12.22.2006, 11:01 AM
Ditto!
I've done the same. I have (8) UE Supershocks on the truck and four in the toolbox with different oil for "quick changes" trackside. Might deceide to go with only (4) then I'll have (3) shock combos ready to rock at a moments notice. :027:
neweuser
neweuser's Avatar
12.22.2006, 11:10 AM
Ditto!
You got a pic of your truck by chance?
Procharged5.0
12.22.2006, 11:28 AM
Only parts of it. It's fully disassembled at the moment. All parts are being polished, trans is being upgraded, brushless will be installed (as soon as I make a decision and order it), etc.
Here are partial pics..........
ID:	2096   Click image for larger version
ID:	2097   Click image for larger version
neweuser
neweuser's Avatar
12.22.2006, 11:45 AM
looks good. What compound are you using for polishing?
GorillaMaxx360
GorillaMaxx360's Avatar
12.27.2006, 11:21 AM
does polishing realy do that it looks more like chrome to me what did you use to polish them.
