neweuser
neweuser's Avatar
12.22.2006, 11:53 AM
Originally Posted by Procharged5.0
No quick answer to that.
If the part starts out in great condition, like an out of the package UE or FLM part I polish with Tripoli on a Sisal wheel then with Jewelers rouge on a soft cloth wheel. I follow that up with hand polishing using Mothers Billet polish and/or Wizzard Polish and Wizzard polished metal protector.
If the metal is anodized, has scratches or deep pits the process starts differently but ends the same way.
The reason I ask is because I would like to polish my slipperential, and my FLM bulks, which come pretty dull. I would also like to do my x braces as well. It seems the 6061 aluminum is more likely to start dull, but would like a better finish on them. Would the Wizard polish and protector do me justice in this? My racer X comes polished, so that ain't so bad! But, I would like the rest to be shiny too! :027:
thanks Man!
Procharged5.0
Procharged5.0's Avatar
12.22.2006, 12:03 PM
I have an extensive and comprehensive assortment of "polishing tools" at home. I have 5 different compounds, more than a dozen polishing wheels from 3/8" dia up to 8" dia. Plus 6 different polishes, 11 grades of sandpaper (36g - 1000g), 3-grades of scotchbrite, bentchtop buffer w/ 1/2" mandrels, dozens of diferent grades & shapes of files, and numerous other things that escape my mind this morning. To polish things like the trans case and the bulks (both are a bitch to polish and time consuming) you need a wide assortment of materials & tools to do it successfully. I think the results of my work speak for themselves.
To start out though, go to your local homecenter , SEARS, or industrial hardware store and pick up ENCO polishing wheels and compounds. You can use a power drill but will need a way to secure the part without damaging it to polish it.
You can also locate a used motor, like from a dryer, mount it to a workbench and buy a 1/2" arbor adaptor. (1700-2500 rpm works well)Then you hold the part while you polish it.
Does any of this help????
neweuser
neweuser's Avatar
12.22.2006, 12:29 PM
Oh yeah, just need the idea and go from there is all. You did well! Thanks! I have dremmel for the small spaces too. But the wheels you get with it are cheap and weak IMO. But a nice buffer wheel would be good.
