Serum
Serum's Avatar
01.03.2007, 05:15 PM
Yeah, i noticed the very same.
You can see it in my movie of the crawling revo.
The mamba maxx seems to do this to act smoother. and it works.
the mamba-maxx doesn't start at 2 rpm, it has a limit of several rpm's per minute. (to produce the needed EMF for sensorless) after it reached the starting RPM range, it can go lower. it's a neat trick to prevent cogging IMO..
01.03.2007, 05:35 PM
Yeah, it is a neat trick, but only if you are using 2-pole motors. Even then, that feature sounds like it would be most useful for smaller motors (like their bundled solutions) since they don't quite have the torque of a larger motor.
I suspect that if Castle releases a firmware update to use 4 pole motors, we'll find the ESC acts more like a normal ESC.
