The 18/120 controller works the same way. Treat the two leads that are soldered together as one lead. The bigger controllers like this have two boards wired in parallel(hence the double wires). I am 100% sure on this (I run the 18/120 in one of my emaxxes).
I use deans for the same reasons you stated-they don't allow the simple mistake of miswiring to be made. they also can handle quite a bit of current.
