squeeforever
squeeforever's Avatar
01.09.2007, 12:07 AM
I would do alot of things to be honest. It basically depends on alot of things though. Do you have a problem going to 17mm or 23mm hubs? If not, I would do a 8mm axle conversion. If you are interested, I'll give you all the links you need to do it. I would also go with GTX2 f/r bulks. They are a direct replacement and are alot stronger. I would also do the buggy upper arm mod. They are alot stronger, less slop, as well as allows you to use buggy 22* front hubs. There are alot of things you can do to it. I would recommend truggyracers.com. They have a list of all the modifications you can do.
By the way, as for hop-up parts (aluminum), I would go with Edit RC parts. There pretty much the only place to get them....
