Mike.L
Mike.L's Avatar
01.16.2007, 09:52 PM
I noticed this WOW seems like a good esc (but its for aircraft)Castle creations obvioulsy makes it but the price seems good.
HERE IS THE LINKhttp://www2.towerhobbies.com/cgi-bin...?&I=LXLBY5&P=7 any good?
and here are the specs:This is the Castle Creations Phoenix HV-110
High Voltage, Brushless, Sensorless Electronic Speed Control.
FEATURES: Handles up to 36 NiMH/NiCd, cells or 12s LiPo (50V) maximum, 16 cells
NiMH/NiCd or 3S LiPo minimum
Up to 110A continuous current
Forward and reverse
Auto Shut Down when signal is lost or radio interference occurs
Smooth reverse exponential throttle
Audible Arming Signal
Self-calibrating endpoints: maximizes usable stick travel
Over temp motor cut-off with reset
User programmable options include:
Low-voltage cutoff with Auto-LiPo detect as default
Over-Current Protection
Brake Type
Throttle Range
Timing Advance
Cutoff Type
Soft Start ramp up prevents damage to gearboxes
Switching Frequency
INCLUDES: One Phoenix HV-110 Electronic Speed Control with 10AWG motor and
battery leads, Universal receiver connector and set up manual
REQUIRES: Receiver battery pack, Dual Opto-Coupled (no BEC)
Motor and battery connectors of modeler's choice
SPECS: BEC: None (dual opto-coupled)
Maximum Cells: 36 NiMH/NiCd, or 12s LiPo (50V)
Continuous Current: 110A
Minimum Cells: 12 NiMH/NiCd, or 4s LiPo
Switching Rate Programmable: 13, 26, or 52kHz
Resistance: 0.001 Ohms
Brake: Programmable
Reversible: Yes, change any two wires
Low Voltage Cut-Off: Programmable
Size: 1.55" x 2.8" x 1.25" (39mm x 71mm x 32mm)
Weight (with wires): 5.3 oz. (150g)
Receiver Connector: Universal
...FROM TOWER HOBBIES
  Send a message via MSN to Mike.L
