Bomb-Proof
02.01.2007, 02:49 PM
That was a Ue driveshaft.
Not always true, much of this depends on what you hit, how you hit, speed, weight, and many other factors. Anything can break no matter what. IMO. I have Revo shafts break as well, not to mention any other part. And again, this all depends on what you hit, how you hit it, speed, weight, etc.....IMO, nothing is "bomb-proof", there are just too many variables to anything. .02
So when you beef everything else up the breakage doesnt start over? But everything breaks as you say.....everything but UE??
This is how it goes..on an Emaxx
Driveshafts weak-upgrade to UE
Diffs weak- upgrade to 1/8scale
now idler gears are weak- upgrade to UE
1st-2nd gear,drive dog are weak- upgrade to ultrmaxxed
input shaft is weak-custom machine one w/stronger steel
wheel hex weak-upgrade to 23mm
Now....driveshafts break. It starts over.
I agree 100% everything breaks. If you can get something to absorb those stress spikes you can greatly reduce the amount of breakage. Steel doesnt give, it sheers.
I agree 100%, any vendor not just UE. People keep using UE as example, so I am also..I based my tests on UE. UE was the best example of a CVD at the time I was running the E-maxx, the "best you could get" Fill in the blank with any name brand you wish.
This is another out take from the Bomb-Proof hates Robin Oury monologue we're all quite tired of.
not exactly, true I dislike Robin, but has nothing to do with this. If it was RDlogics, I would say the benifit would be people who like RDlogics stuff would like the truck better.
