glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.08.2007, 12:45 PM
Oh... check out the monster fan over the motor/esc. That's why I stuck the esc there, so I could get two birds with one stone. The fan moves a lot of air. I ran this setup for over 30 minutes nonstop at the track in 90* heat and both motor/esc stayed around 150-160ish the whole time. It actually was a few degrees cooler right at the end than it was at one point earlier in the run.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
