Serum
Serum's Avatar
02.17.2007, 08:01 PM
Yeah, schulze did.. Loose contact!!!!!!!!!!
i personally think it's because of the motor braking, which can causes higher spikes. a fet is allergic for that, as you know.. :) there are some kind of diodes, you can buy at a set voltage (lets say 24V, and anything above that 24V is killed (regulated till 24V). can't recall their name.. but they can handle an awfull lot of power.. and you can put them paralel over the source. (motorwires in this case) so three of them.. never tried them, but i am pretty sure you will keep the fetts in their safe range..
02.17.2007, 08:11 PM
Hmm. Most FETs have the diode you are talking about integrated into the FET package. As to the name of the diode: Are you thinking "avalanche diode" or "zener diode"?
