GriffinRU
02.18.2007, 05:16 PM
Originally Posted by Aragon
Check out www.neumotors.com and www.flydma.com. Both have useful info on the Neus.
Thank you,
Second link has the data I was looking for :)
Artur
02.18.2007, 05:32 PM
Good job!
A suggestion: Could you put the links to download the apps in your sig. That way, we all know where to get the most current version without trying to dig back through the thread...
GriffinRU
02.18.2007, 06:19 PM
Originally Posted by BrianG
Good job!
Ok, I will do that later.
Artur
GriffinRU
02.24.2007, 04:11 PM
Updated version 1.0.3 (7.5MB)
pinolelst
02.24.2007, 10:31 PM
I just installed the updated version and get this error message,I deleted the previous versions folder prior to installing the new version if that helps.
thanks in advance
Steve
Name:	motor eval error msgresize.jpg
02.24.2007, 10:54 PM
It loaded fine for me.
It looks like the new version uses an excel file to store motor data. Do you have Microsoft Excel installed?
02.24.2007, 11:24 PM
I like this new version! The addition of having motor data in an external file is nice! Great job.
OK, now for a couple of suggestions.
In the attached pic, there are two circled areas, "Note 1" and "Note 2".
Note 1: It looks like there is a little alignment issue where the column name over-writes the other column. Not a big deal, just wanted to point it out.
Note 2: The units are not shown. Most people know that torque is in oz-in, power is in watts, etc - but it may not be obvious to some. Maybe put the unit in parenthesis, or at the end of the output field? The units are displayed on the columns, so maybe that's good enough and I'm just being too picky. :)
Is it possible to add a pointer so that if you click somewhere on the x axis, it will display the values for the curves at that point? For example: Let's say I want to see exactly what power, current, and speed there is over a certain efficiency range. I would click somewhere on the efficiency curve and then some type of informational box would appear showing the values of the corresponding curves at that point on the x axis. Again, not a big deal - it would be just another neat feature.
Thanks again for this tool! It is looking very nice!
pinolelst
02.25.2007, 12:48 AM
No but I have open office installed.Maybe I have to make it the default ?? Dunno Imma gonna give his fix a try.
thanks
pinolelst
edit: That fixed it for me.thanks
GriffinRU
02.25.2007, 12:26 AM
thanks in advance
Steve
Well, I was using Excel to make it simple... but I will create another way to edit database. For now you can download attached file and unzip it to program folder.
I am using Excel only to import data, program only reads Excel upon first run (to create separate file) and when user clicks update via menu. This way you have more flexibility with data.
Artur
GriffinRU
03.02.2007, 01:29 PM
thanks in advance
Steve
Finally nailed this one, it is related to MS Office version. I wrote program under office XP if you have MS Office earlier version then you will get this error. I am working on resolving this issue.
