Sower
Sower's Avatar
02.16.2007, 04:38 PM
Originally Posted by Serum
Trakpower uses a special grade of enerland cells. they are not 'just' enerland cells.
and since two trackpowers are cheaper, the answer is obvious.. :p
Right. I was actually thinking of doing that - putting two of them together would make it a 4 cell 4900. I was looking at a couple of the other 2 cell Enerlands too. Not as tempting as the two Trakpowers. What do you thik Serum - are the two Trakpowers, the Lehner 1950/7 hi-amp, and MM esc going to give me a great system that will stay cool?
AAngel
02.16.2007, 09:24 PM
I don't know if this means anything, but I just tried to program my MM and when I started the app, it told me that a firmware upgrade was available. Is this the fix?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.16.2007, 10:42 PM
I wish it was...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Serum
Serum's Avatar
02.17.2007, 04:06 AM
Nope, the update is a fix for the lipo cell count..
Yeah, the setup you have in mind will be awesome!!
AAngel
02.17.2007, 04:39 AM
That's funny, because I've never had a problem with my MM detecting the cells. In fact, I wasn't even aware of this issue. We just happened to finish my friends 8ight tonight. We got the MM in from Mike today. Plugged everything up, jacked in a 4S pack and it only beeped twice. I wasn't happy, after what he had been through dealing with Finedesign. I decided to try the flash with the new firmware and all is well.
I suppose we should just keep twidling our thumbs, or perhaps just go out and buy a Quark. I really wanna get that Neu. For some odd reason, I just don't find the Lehner as appealing.
Serum
Serum's Avatar
02.17.2007, 05:01 AM
Trust me, once you have a lehner motor in your hands, it's sweeter than sweet. Besides its ugly sticker and ditto purple end bell, it's simple a precision produced tool..
Sower
Sower's Avatar
02.19.2007, 11:09 AM
I'm just curious - what about the Lehner don't you like? Other than what Serum mentioned about their disco packaging. They should put a few rinestones around it or something and just go all out.
AAngel
02.19.2007, 12:38 PM
The Lehner that I was interested in was the 1940/7, but it has a 4mm shaft. If I got with a Lehner, it might have to be a 1950, just because of the shaft diameter.
Sower
Sower's Avatar
02.19.2007, 04:01 PM
What's wrong with the 4mm shaft? Is it pinion availability? If so, RC-Monster has 4mm pinions.
jhautz
jhautz's Avatar
02.19.2007, 11:33 PM
mike can make you an adapter so any 5mm pinion will fit the 4mm shaft. I have one he made. It works great. Used it to figure out the gearing I want with my 5mm pinions. Then ordered the correct 4mm pinion. But you could just use the adapter permanently if you wanted to.
to make it...
or break it...
Silent...But Deadly
