BMW M Power!
BEC in Micro-T? -
03.01.2007, 09:48 PM
Hey, I have a Micro-T in a box sitting in my room that I was going to sell (its still stealed and brand new). I was going to run it with some buddies, but they never bought one, so I never opened it.
I want to run something with more power than the stock battery, but dont want to drop the cash on brushless. However, I dont want to risk the speed control by running 2S lipo. I was thinking of running the 2S through a BEC first, so the ESC receives only 6v. This should help alot, since the ESC will receive an absolute max of 6v and not stuff like 8.4 on a freshly charged pack.
The stock battery is 150mah, and I heard it runs for like 10 minutes, so amp draw can't be more than an amp or so at most. I figure a 3A BEC should be plenty for it.
Any thoughts?
03.01.2007, 09:54 PM
That should work fine. I would go with the one www.dimensionengineering.com has. It has a built in LVC as well. I to was thinking the exact same thing...
BMW M Power!
03.01.2007, 10:11 PM
Thats a great site squee - has a bunch of cool products.
Too bad they don't make the "SmartBEC" in 6V. They only make it in 5V. That should still provide a pretty noticable increase over stock, just not as much as I had hoped. I will keep shopping around though.
I also found another problem. Doesn't the Micro T use an integrated receiver/ESC? This would prevent the ability of using a the Cutoff.
03.01.2007, 10:49 PM
no bp theres no need, the stock can do it just fine, ur just adding on un needed wieght
03.01.2007, 10:50 PM
Unfortunately, it does...If you open up the Micro-T, could you measure the battery compartment for me please? I just placed an order for a 460mah LiPo cell, and a few small things to build the pack. It should fit, or if not, I think I can make it fit. Its only about 8mm longer...
03.01.2007, 10:51 PM
Are you sure the stocker can take double the voltage it is intended for?
03.01.2007, 11:14 PM
yup, its actually rated for 7.2 volts
go ask anyone at one18th, they all run the stock sreedo no probs... some upgrade to a novak speedo, but most run the stock stuff, the motor and speedo does fine, and i have tired it to with a lipo from my buddys micro t,i used a max amps 2 cell 150 mah i think and it had room to spare
03.01.2007, 11:18 PM
heres a pic to prove it stright from losi, look at the sticker, it says 4.8 volts to 7.2
BMW M Power!
03.01.2007, 11:23 PM
In the manual it says otherwise... It says max is 4.8 and use of Lipo voids it etc etc....
03.01.2007, 11:26 PM
bull, it works fine man, as long as the pack isnt insane mah.. squee is probably pushing it, id do 220mah MAX after that is when probs happen because it runs for waay over 30 mins
03.01.2007, 11:27 PM
Exceeding the mah rating won't cause any problems other than fitment. Actually, it's better for the battery to discharge less than it's rated for...
03.01.2007, 11:29 PM
yeh it will because they run soo long and heat up the motor, and speedo... the motors rated for 4.8 volts so ur wearing it that mush faster with lipos, and speedo heats up
03.01.2007, 11:35 PM
Thats why I'm only gonna run 1 LiPo cell for now...
03.01.2007, 11:39 PM
why????? do u want a vid??? or what??? lol it works fine
03.01.2007, 11:42 PM
That's a weak reason! Sounds like some effort needs to be made in cooling if that's true. :)
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
