glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.05.2007, 04:25 PM
Oh.. and I ran the 30 minute main... should have been almost 32 minutes total track time. The 8000pack charged back 5440mah... 170mah per minute.
I wish I could always count on that! The 5000mah pack just might have done it if I skipped the warm up laps!!!!
I should have run the 5000 pack.... the car would have handled better too so maybe I would have done better.
One last thing:
With the 8000mah pack it weighs about 2oz. more than my buddy's nitro 8ight full of fuel. He also has a heavier body... probably a good 2oz more than the stock one.
With the 5000mah pack it only weighs 7lbs 3.6oz... a full half pound less than the nitro.
I did see another guy on rctech say his (nitro) 8ight weighs 7lbs 3.3 oz wihtout fuel (would be @7lbs 7.5oz. with full tank).
The 8ight is so light, some guys are putting lead weight in the rear... but it's cool to have an BL that weighs less than a nitro and can run almost 30 min.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skeeler
03.05.2007, 04:32 PM
glassdoctor,
Could you give us any more information about your setup, other than what's in your signature. I'm just getting into the world of BL conversion, and I like to see as many examples as I can, in as much detail as possible, of good conversions. Also, could you post some recent photos, or point us to some that are already online?
Thanks again for your patience.
skeeler
03.05.2007, 04:41 PM
By the way, glassdoctor, would you recommend the Mamba Max/New 1512 combination? I'm thinking I'll probably use a 1512 on my buggy project.
Oh, I see you just replied to my previous query. Thanks.
