glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.05.2007, 04:32 PM
Bump up the gearing a little if you need more speed. I run the lower kv motors and can run in the 40's if I want to... just requires a taller gear.
But the 2d isn't exctly a crazy hot motor for an emaxx... much better than the 3000kv motors we used to run.
So really what I am saying is that either motor will work well... the 2d or 2.5d... just gear accordingly and you may not even tell the difference.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
