JakeE
03.06.2007, 01:40 PM
Originally Posted by nolatron
Pretty sweet.
Do you know if a Feigao XL motor will fit with that mount?
And how would I go about getting one of these as well for my hyper 7 project :)
I think a Feigao XL motor should fit but I'm not certain of the screw spacing on the Feigao motors, someone else probably has a better idea about this than I. Email Mike and let him know what you're looking for. I think he has also made a more traditional mount that places the motor off to the side of the center diff.
EDIT: I should have refreshed before posting :)
lydiasdad
03.06.2007, 06:02 PM
Does the body fit ok with that motor mount or will it need to be raised?
03.06.2007, 12:41 PM
Yes, it should. The Neu motor screw layout is slightly wider than the XL series and you can see in the pic of the mount that the Neu has to sit somewhat cockeyed for the screw holes to line up with the mount slots. An XL should fit perfectly. I actually used a dremel tool to widen the slots a hair so the motor doesn't have to be cockeyed and can sit lower to the spur, which allows me to use smaller pinions.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
03.06.2007, 12:46 PM
how is your gearing?
losi 8ight-t
xray xt8
nolatron
E-Revo Basher
nolatron's Avatar
03.06.2007, 12:50 PM
Thanks for the welcome. I've been a lurker for awhile. Some have probably seen my video work with sleebus.jones on youtube.
As for the XL, I was more worried about the length of the motor can. From looks at the pics, that rear support rod looks like it may be a little too close for comfort when a longer can motor is dropped in there.
jollyjumper
RC-Monster jumper
03.06.2007, 12:53 PM
an XL is 14mm longer then the 1512.
losi 8ight-t
xray xt8
jhautz
jhautz's Avatar
03.06.2007, 12:55 PM
Another thing you should pay attention to is the XL motors shaft is not quite as long as the Neu motor shafts. These guys have their pinion gears set on the shaft with the set screw out, you my not have enough room to get a set screw on the shaft in that orientation. You might want to have Mike mill a slot down in the face of the motor mount to allow access to tightening and losening the pinion set screw if you have to turn it around.
I ran into this once when making a motor mount once. It worked fime with the longer Neu shaft and the pinion set screw at the very end of the motor shaft, but the XL shaft was just a little to short to work without turning the pinion around, and then I couldnt get to the set sew cuz it was inside the clearance slot in the aluminum motor mount.
Not sure if it will be a problem, but just something to be aware of is all.
to make it...
or break it...
Silent...But Deadly
03.06.2007, 12:54 PM
I understand your concern about the length of the XL can. However, you have to remember that the Neu is substantially larger in diameter, so it will get close to the rear brace even though it is shorter in length.
I have my 10XL out of the Revo right now, so I could make a quick test fit if that would help you out. It'll have to wait until tonight when I get home though...
nolatron
E-Revo Basher
nolatron's Avatar
03.06.2007, 12:57 PM
I would most appreciate it. thanks :)
hunter306
hunter306's Avatar
03.06.2007, 01:06 PM
Nice setup, Gives me something to work toward, along with Briang's design.
I've got my Hyper7 stripped down to the chassis right now, I'm talking to mike about getting one of these mounts fabbed up.
Great work, can't wait to see it all come together.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.06.2007, 06:07 PM
My Kyosho has a motor mount like that and it has TONS of room under the body... the motor is nowhere near hitting the body on mine...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.06.2007, 06:18 PM
Yup, what GD said: plenty of room...
Mainly, it gets tight on the sides and the front where the shell is the thinnest...
JakeE
03.09.2007, 01:34 AM
More progress:
I made some shelves for the batteries today and did a rough layout for the electronics. I still need to finish my battery packs, add balancing wires and shrink wrap them so they can be velcroed to the shelves. It's a hefty beast, weighing in at 8lbs. 12oz. Unfortunately I'll have to wait for the snow to melt before I can really test it out.
Most importantly, the body still fits :)
JakeE
03.10.2007, 07:21 PM
It's alive :D
I tested it briefly on the patch of dry pavement in front of the house, sadly there's not enough room to let it hit full speed.
rchippie
rchippie's Avatar
03.10.2007, 07:30 PM
Jake your buggy looks AWSOME :004: :004: . Is that a rc- monster center diff mount ?.
REAL MEN RUN BRUSHLESS
