#4
lehner vs. mamba -
03.05.2007, 09:04 PM
hey guys,
have a quick question. i have a mamba 5700 in my stampede and was wondering if i were to get a lehner basic 5300 would there be any more power, efficiency, runtime? whats the rpm limit of the lehner basic series? nvm i found it, why is the lehner motor's max rpm limit alot lower the mamba's?
03.05.2007, 09:19 PM
It's not...the Lehner Basic's should be 65,000 rpm, the same as the MM motors.
http://www.lehner-motoren.com/msbasic.php?la=en
#4
03.05.2007, 09:35 PM
thats weird, when i typed my info in the speed calculator it told me the lehner basic rpm limit is 40,000
03.05.2007, 09:45 PM
That's not a manufacturer specified limit, but recommended limit. Some motors tend to lose efficiency past that point.
#4
03.05.2007, 09:47 PM
o.k, that makes much more sense. so its o.k to run the lehners around 50,000-55,000 rpm?
03.05.2007, 09:53 PM
Its ok , but not reccomended, will shorten the motors life, and will run hotter.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
03.05.2007, 09:57 PM
And heat weakens/destroys the magnets. Not to mention the extra heat and wear on those poor bearings.
#4
03.05.2007, 10:03 PM
so i should run around 40,000
BMW M Power!
03.05.2007, 10:12 PM
Well, you should also take into consideration that Lehner KV figures are loaded (though I'm not sure about the basic's - can ayone comment on that?) while castle KV values are unloaded.
Anyway, 40,000 should be the limit. Its ok to go over a little, say a few thousand RPM, and its ok to have less RPM (some even run as low as 30,000).
#4
03.05.2007, 10:42 PM
alright thanx guys.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
