glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.07.2007, 11:05 PM
Originally Posted by VintageMA
I think you guys are missing something in your calculations of high voltage = less amps. If you take the same motor with the same KV rating, higher volts will = higher amps.
I know I'm not missing it... :010: ...to increase the voltage you must reduce the kv accordingly. I assumed that would be assumed. :030: hee hee
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
VintageMA
VintageMA's Avatar
03.08.2007, 12:44 AM
Well it's just a point I wouldn't assume everybody reading these threads would know to make.
When I first got into this I would've just thought "Oooh, faster motor cool!!" Without first understanding that means higher current draw, lower starting torque, and generally a drop in source voltage as the resistance of the motor starts to drop to that of the internal resistance of the cells.
“Everyone has a right to be stupid; some people just abuse the privilege.”
