03.09.2007, 08:50 AM
Can't answer your gearing question as I'm not familiar with that vehicle, but whether you need a UBEC or not is determined by the main battery pack voltage. If you are running over 8 cells or 3s lipo, get a UBEC.
And in case you don't know; a BEC is basically justy a votlage regulator which converts the main batter pack voltage to 5 or 6v for your receiver and servos. The BEC in most ESCs are linear, and will heat up a lot if using higher cell counts. The UBEC is a swithincg device so it runs much cooler and more efficienty.
Bronco
03.09.2007, 08:56 AM
Forgot to mention it : I run the truck with Team Orion's Platinum lipo's 4800 (which are 4 cells 2S2P). Which means they are considered 2 cells not ?
So I do not need a BEC/UBEC ?
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
03.09.2007, 09:27 AM
i'd use a 18T pinion.
and no need for ubec on 2s lipo.
losi 8ight-t
xray xt8
Bronco
03.09.2007, 09:52 AM
Thanks jollyjumper, so using an 18T on a 86 spur wouldn't that limit the top speed ?
Is see you're also from Belgium. I race in Arendonk, maybe you know the track.
If you do know it would 18T get me up to top speed at the main straight ?
BTW, were do you race ?
