JakeE
03.10.2007, 11:58 PM
Originally Posted by MetalMan
How is the Sport BEC treating you?
Nice buggy conversion! Are you running a 5s2p setup with the A123 cells?
Yes, it's a 5S2P A123 pack. So far so good with the SportBEC, it doesn't have a definitive contour so I stuck a piece of velcro on the flattest side and affixed it to the shelf I hung off the center diff mount. Time will tell if a more secure mounting method is required. I don't have any experience with other BEC devices so this may not be anything special but the SportBEC acts as a pass through so no modification to the Mamba Max receiver connector is required.
JakeE
03.11.2007, 11:02 PM
Here's a current/voltage graph of a few speed passes I did today. I should pick up an RPM sensor so I can get an idea of speeds I'm hitting.
