glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.12.2007, 07:46 PM
Yes... same type of power.
To disable the bec you simply pull hte red wire from the reciever connector... and use a separate bec or rx pack to power the rx and servo.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skellyo
skellyo's Avatar
03.12.2007, 08:57 PM
Don't let the FD package fool you. The XLT motor he sells is no more powerful than a Feigao 540 XL, which is what I believe it actually is. The big difference is that the shafts are 1/8" on them....yuck :020:
And just to dispute his specs...
1HP = 746W
How the heck does he say he has a 2.5HP motor that is 1500W? :rolleyes:
IIRC, the Feigao 540 XL motors are 1500W also...big coincidence, huh?
And not to be mean, but if after reading this forum, you still go buy a BL system from him, you should be tarred and feathered :D
