squeeforever
squeeforever's Avatar
03.12.2007, 10:05 PM
Personally, I'm not surprised you aren't happy with the HV setup. You seem to have a good truck, just not the best BL setup. As for the LSP, I think the 9XL and a MM would be a good setup. Whether you want to run 4S or 5S is up to you. The MM is safe on 4S, as well as 5S, but 5S is the most you can run on it. Personally, I wouldn't run it on 5S all the time. If you deside to run 4S, I would go for the 8XL, or 7XL for a little more speed, depending on if your concerned about runtime.
