elegal
03.15.2007, 11:09 AM
I want to be able to use them in an emaxx a well, plus I like the extra protection provided by the trakpowers.
They would be staggered enough to allow the bottom battery to be plugged in.
I would wire the harnesses together just like one big pack, the balancer and charger should see them as one large pack, and i shouldnt have any voltage problems if i discharge them at the same time in the same car.
I would just need another balancing cable to balance my other batteries.
skellyo
skellyo's Avatar
03.15.2007, 11:21 AM
Sounds logical to me. The only thing you should need is an extra Trakpower balancing harness so you can custom make an adapter for the V-Balance for 4S. For me, since I have two ICE chargers, I just ended up buying two of the V-Balancers that included the Trakpower harness.
pinolelst
03.16.2007, 04:40 PM
I've read somewhere a manufacturer saying 2 cell packs are less problematic as far as imbalances go than 3 cell and above but I think that's not really entirely true.An imbalance between 3 cells can happen just as easily with 2 IMHO.
I added balance taps to all my older packs and was surprised how hard the balancers were working the first time.Looked like christmas tree lights blinking on and off :005: Far more than a new pack put on the same balancer so I have to assume they were pretty far out 20 or so cycles into their lifespan.
I balance about every couple 3 cycles now and find that works about right for me .
hope this helps
Steve
crazyjr
crazyjr's Avatar
03.17.2007, 10:18 AM
hope this helps
Steve
I always thought that was on the parallel side, but i guess anytime you put an extra cell in a pack it makes ot more complicated and more liable to possible problems
