01.24.2007, 12:30 AM
Removed the new feature due to Mozilla browser not following the W3C rules. :mad:1
Edit: Nevermind. I got it to work except in Opera...
01.29.2007, 01:48 PM
how about adding the plettenbergs to the motor list... Maxximum, Maxximum w/fan, BigMaxximum w/fan, Shadow, Extreme, Bolido,
01.29.2007, 03:31 PM
I would... if Mike carried them. Since this is his forum, I try to stick with products he carries...
01.29.2007, 04:50 PM
I am pretty sure mike can get the pletts. He just don't carry them for low demand.
Peace!
Country
Help support the
Rc-Monster
Buy here
01.29.2007, 11:10 PM
Well, if you say it's ok, it must be since you're a mod. :)
OK, so, what motors do you want on there? I'll enter them, you just have to do the research. ;)
I'll need the following:
- Motor name/model
- kv
- max efficient rpm recommended by the manufacturer
- quality rating. This is a three point system; "good" (Feigao/Wanderer), "better" (Mamba motors, LMT Basic series, etc), "best" (LMT, Neu).
- The can size; 380, 540, etc
- motor length
- motor diameter
- weight
- flange diameter if any. (the raised area around the shaft)
- shaft length
- shaft diameter
The first 3 are mandatory and are needed for all motor calculator pages. The next 2 are for the motor selector page - if there are no values, that motor won't ever be offered as a choice. The last 6 are simply for informational purposes for the "Misc data" page.
01.30.2007, 08:30 AM
Do you need kv under load correct?
BTW I didn't see a 17turn lehner on there. :)
Peace!
Country
Help support the
Rc-Monster
Buy here
01.30.2007, 11:16 AM
Yes, preferably under load if available.
At the time the original motor list was created, I stuck to items Mike carries in stock since those seem to be the more common ones. Even then, the list seems a bit long. It has grown to the point now that I don't think it'll matter if I add two or two dozen. :)
02.03.2007, 06:24 PM
Just added a diagram to the Lipo Wiring page (scroll to the bottom) which shows how to wire up balancer Y adaptors when using two seperate packs. Currently, there are only entries for Hyperion balancer connectors, but if someone wants the wiring scheme of other types of connectors, let me know...
02.03.2007, 06:26 PM
Nice addition Brian! This will help many since there arent any clear diagrams on how to wire the balancers up! Thanks!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
02.03.2007, 06:27 PM
No problem! :) I too noticed there were not too many diagrams and saw that question asked several times.
02.04.2007, 02:23 AM
That saves me some time :D.
03.16.2007, 05:05 AM
I don't know what's going on, but the server where R/C Calculations is hosted is having problems. I called them earlier today and they said it would be only a few hours to fix, but it's been over 12 hours.
Anyone want to host a mirror? I can supply the files in a ZIP archive. Mike? :)
03.16.2007, 09:27 AM
Looks like starluckrc is hosted by the same guys...
03.16.2007, 09:34 AM
I have my whole site hosted through 1and1.com, which were quite reliable (up until now). Grr. But I suppose these things happen. Makes me wonder how hard it is to simply replace the bad component in the server? Even if that was a bad disk, I can upload everything again. I'd rather do that than wait this long. All I know is if the servers I am in charge of where I work were down this long, I'd be in the unemployment line!
03.16.2007, 02:18 PM
Good thing you don't work there then. We may have some good deals for you
RCs. ;)
Peace!
Country
Help support the
Rc-Monster
Buy here
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
