skellyo
skellyo's Avatar
03.26.2007, 12:10 PM
Originally Posted by Finnster
Are people still buying this motor much? I'm curious what has happened since the mambas came out, and how this motor compares to the 5700. The little testing I've seen seems to say the 380 is a bit faster, but the 5700 can run 3S, so passes it on higher cell counts. Anyone else seen anything?
I don't know if it's selling as well now with the Mamba Max motors available. However, from reading a bit about it on some other forums, I believe it uses the same diameter rotor as a MM motor. Couple that along with the longer rotor and I think it's a better motor for someone wanting to run on 2S only. I would certainly buy one of these again before buying a 5700 for a stadium truck.
