Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
03.26.2007, 12:05 AM
No, that would wear out wayyy too fast. You put it on the inside of the tire.
ncalenda
Need for Speed
ncalenda's Avatar
03.26.2007, 12:35 AM
I'm getting new pro-line MT tires, should I do this? I get balooning now.
  Send a message via AIM to ncalenda
jhautz
jhautz's Avatar
03.26.2007, 12:42 AM
I thought that the MT tires had ribs on the inside to reduce ballooning. If you are using them now and get too much balloon, then duct tape should fix you up.
to make it...
or break it...
Silent...But Deadly
ncalenda
Need for Speed
ncalenda's Avatar
03.26.2007, 12:56 AM
Thanks for the info, no I'm using the revo stock tires, I should get the MT tires tomorrow.
captain harlock
RC-Monster Captain
captain harlock's Avatar
03.26.2007, 12:21 PM
Guys, can you post a pic of a duct taped tires?
Nice to meet you!
Serum
Serum's Avatar
03.26.2007, 12:28 PM
something like this;
captain harlock
RC-Monster Captain
03.26.2007, 12:32 PM
Did you fix the insert to the tires internally with ducted tapes, or just the inside of the tires?
Nice to meet you!
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.26.2007, 12:44 PM
That's just the tire... turned inside-out and wrapped with tape. Then you flip it back and install with foam etc as normal...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Serum
Serum's Avatar
03.26.2007, 12:46 PM
Amen Glass.
captain harlock
RC-Monster Captain
03.26.2007, 09:00 PM
Then, the idea is to fill up the gap between the tire and the insert, right?
I should try it very soon.
Nice to meet you!
MetalMan
MetalMan's Avatar
03.26.2007, 10:10 PM
The MTR tires do have internal ribbing that should reduce ballooning, but in my experience, it doesn't help. The Bowtie MTRs on my Revo get almost as large as the Crime Fighter MTs do!
glassdoctor
TEAM FUSION
03.26.2007, 10:23 PM
Well not really... the ides is that the tape won't stretch. So when the tire wants to stretch and balloon out... the tape can't. If the tape is stuck good enough to the trie, it will hold the tire at it's normal diameter.
Just like if the tape was on the outside.. you can see how that would stop the tire from ballooning.... same thing if it's on the inside, assuming it's sticky enough to stay stuck. :)
Stretchy tape wouldn't work... it must be a duct or strapping type...
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.26.2007, 10:34 PM
I've heard gorilla tape works well as it is quite sticky. Just don't forget to clean the residue off the tire first.
captain harlock
RC-Monster Captain
03.27.2007, 07:43 AM
Nice, nice, ver nice!..:)
GD, Brian, I announce both of you as Deputy Captains as of today.
Congratulations!:005:
Okay, a different question:
Is there a possibility that I can change the gears of the slipperential from 21:44 to something like 24:40 ?
I want to decrease the gear ratio to make it as low as possible. 2:2 ratio is quite high and I've noticed that the truck was somewhat undergeared.
I want to change the slipperential's own gears( of the center diff and topshaft) and not the spur or pinion.
Nice to meet you!
MetalMan
MetalMan's Avatar
03.27.2007, 09:45 PM
To lower the ratio of the slipperential would require a different spur gear on the differential. To my knowledge, there are no other plastic spur gears that fit onto any center diffs that have fewer than 44 teeth, besides the one on the Revo that has 28 teeth (but that's a completely different diff).
