04.01.2007, 10:36 PM
You can test this BEC theory by using a receiver pack temporarily (don't forget to remove the red wire in the throttle cable). Even though the heatsink isn't hot, the BEC (which is just a linear regulator) could be overloaded depending on your servo load and shutting down.
