Lipo advice needed...
xjbebop
...so much to learn...
Question Lipo advice needed... - 04.14.2007, 07:38 PM
I'm almost ready to make the jump from NiMH to Lipo. I want to start w/ my Losi xxxt w/ MM 5700.
I've got a Vision peak ultra charger (and a Hyperion EOS5i on the way).
What would you recommend for a 'best value' battery?
I don't need top of the line (or top $$), but I want good quality, reliability and safety. I'm not racing, just bashing.
There are sooo many different brands and numbers (2s2p or whatever..???) I don't know where to start.
I want something that will fit in the standard stick-pack tray.
I use Dean's on everything. I understand about charging at the rated capacity (3600mah = 3.6A charging...right?). And I need to set the esc to the correct cut-off voltage, whatever that number will be.
Also, is 'balancing' mandatory? I heard you only 'need' to do that once in a while...???
thnx!
