Finnster
KillaHurtz
Finnster's Avatar
04.15.2007, 08:28 AM
Originally Posted by zeropointbug
Finnster, was your hex that you used very tight in there? If it's not in there very tight, the strength of it will be severely compromised. I think it should only be able to be put in with a hammer, or a vice (tighten it up). How was yours?
I can't recall for sure what size now (2mm think tho), but yes, it was very tight and had to be forced thru w/a hammer. It was a real bastard to get thru :)
I have a 8XL running on 4S and 5S. Lots of TQ. Slipper is kept pretty tight so it doesn't slip and heat up too much. Overall I'm not that hard on the truck tho.
ssspconcepts
ssspconcepts's Avatar
04.15.2007, 09:24 PM
Thanks...its good info to have...now we have a bench mark for the 2mm key:027:
ssspconcepts
04.15.2007, 09:25 PM
Now wouldn't it be nice if they came with the mod....
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.15.2007, 10:22 PM
Well, you know... we COULD just weld it. It would have to be a good weld, to maintain shaft balance. Maybe just two tacks on each side?
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
04.15.2007, 11:41 PM
I finally put the hex over to the input shaft .
Boy it was hard to put into with a hammer there is no way it will get slip and out of that hole,for a while I thought it will not go inside,I file it first just like SSS did suggest and it finally went all the way in to the other side with a hammer. here is a pic
ID:	2764   Click image for larger version
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
zeropointbug
Z-Pinch racer
04.22.2007, 05:58 PM
Here is mine that I did. Guess what happens when your pin is to large? :026:
I had to use my old gear after I broke the new one! :035:
But it turned out very well, it was a very, very tight fit. I had to stop hammering it, and use a large vice to force it in. It worked!
ID:	2793   Click image for larger version
ID:	2794   Click image for larger version
ssspconcepts
04.22.2007, 06:12 PM
Glad it worked out for you....looks good.
zeropointbug
Z-Pinch racer
04.22.2007, 11:49 PM
Oh, i forgot to mention, i used a drill bit end. I can't remember what size but i had to grind it down alot, the first one showed it wasn't ground down enough.:024:
So hopefully this stands up to my 7XL. The gear is actually to original gear from my first emaxx.... 6 years old! :005: Still looks as good as the new, only a little grime inside the gears.
