Thread Tools Rating: Thread Rating: 19 votes, 4.37 average. Display Modes
George16
Supermaxx
George16's Avatar
11.11.2008, 06:46 PM
Man, that's a brick!!!!! You can mount it that way using a plastic battery tray to keep it from sliding or just make sure it's snug.
Reminded me of this:
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.27.2008, 10:18 PM
Well, you guys warned me. I have not put a flat spot on my Neu's shaft...yet. I have been bashing for months with a tight grub screw and loctite until today. One minute into a bash with an extra 3.7 volts and I lost the pinion. Luckly no damage to the spur.
I talked my wife into giving the Dremel (one of my Christmas presents) early. I'll be grinding.
11.28.2008, 01:51 PM
How did you survive rc without a dremel?
mkrusedc
NeuMaxx
mkrusedc's Avatar
01.22.2009, 12:52 PM
Here is Mike's custom battery tray. I thought with the way I drive my battery needed a little more protection:
bigboi146
Multi Tasking
bigboi146's Avatar
01.22.2009, 01:06 PM
Looks nice man. Hows your CG with that big battery back there?
mkrusedc
NeuMaxx
mkrusedc's Avatar
01.24.2009, 09:31 AM
Not bad. It is right at the spur, which puts it just slightly behind the center of the truck. A wheelie bar is going to be needed.
Latest upgrade -- Strobe Braces and Knuckle Heads
mkrusedc
NeuMaxx
mkrusedc's Avatar
Latest upgrade -- Strobe Braces and Knuckle Heads - 02.15.2009, 08:31 PM
My latest upgrades Strobe Braces and UE Knuckle Head shock towers. I had to change out the FLM shock towers to the UE because the UE were 3 mm thinner. It was either that or shave the Strobe brace like suicideneil did. I also had to shave the top of my FLM hybrid bulk because the UE tower has an oblique bottom instead of a square one like the FLM.
Clearence issues:
Rear:
Front:
02.15.2009, 08:43 PM
That looks alright, no butchery visable unlike my setup (I plan to keep my truck till Im grey and old, its my pension plan so I figure the rarity value will outway the modifications hopefully ).
Do like the way knuckleheads look compared to the FLMs too
Bigdumredneck
02.21.2009, 11:04 PM
Those Strobe braces look great on there! Im glad they they found a good home!
mkrusedc
NeuMaxx
mkrusedc's Avatar
02.23.2009, 11:12 PM
Thanks Jack. You have helped to complete my build.......I think
jayjay283
jayjay283's Avatar
02.24.2009, 09:06 AM
Completed build it think NOT ! You previously mentioned you may goto 8 Super Shocks. If you want another 4 to complete the set and a new unopened spring set and 3 kyosho boots, maybe we can work out a deal and get some to the Golden goose. If not, perhaps Jerry or Lito has a home for them ? Mark gets 1st declination, but im not going to use them. I have finally gotten my 8 Losi 8T rear shocks working perfect on my Gmaxx and wont be needing these.
NOT a sales thread LOL, Just an offering so dont black ball me Brian
SpeedAssault
SpeedAssault's Avatar
03.30.2009, 12:25 PM
Wow
Nice build
keeping eye on this
more info on oarts used please
Keep up good work
above those are nice looking shocks
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.30.2009, 03:09 PM
Wow
Nice build
keeping eye on this
more info on parts used please
Keep up good work
Thanks this is my current parts list:
Upgrades:
Neu 1515/1y/f
MGM Compro 160/18 controller
5s NeuEnergy 5000 mAh battery
RC-monster custom battery tray
Anderson Power Pole connectors
FLM extended chassis
FLM hybrid bulks
HB 1/8 diffs
Gorilla Max single speed transmission
RC-Monster steel idler
ProLine steering linkage
Strobe slipper
Strobe sprong
Mod 1 gearing 51/20
RC-Monster steel dog bone center shafts
UE RacerX shocks (8)
UE Knuckle head shock towers
RPM suspension arms front
RPM TureTrack suspension arms rear
RPM axle carriers
Traxxas 3.3 turnbuckles
Traxxas 3.3 drive shafts
Traxxas dust boots
Onfa 17mm wheel hexes adapters
Maximizer Bead Lock wheels
Proline Badland tires
Futaba S3305 MG steering servo
Traxxas wheelie bar
Traxxas wheelie bar wheels
Futaba 3PM 2.4 GHz radio
Lundsford Titanium hinge pins
A complete set of Tonys Screws
Strobe bulkhead braces
$ 2,197.00 USD
and recently:
Rear upper and lower UE RacerX suspension arms with knuckles and UE cvds:$187.00
03.30.2009, 08:59 PM
Having a unique truck; priceless. For everything else, there's mastercard...
Kcaz25
Kcaz25's Avatar
03.31.2009, 01:01 PM
Neil, where are the pictures of this alleged butchery? I've looked and can't find much.
Oh, yeah I found it. It doesn't look bad at all.
Tags
e-maxx, flm, mgm, neu, ulimited engineering
