Muggy diffs in a maxx
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
Muggy diffs in a maxx - 12.23.2007, 05:33 PM
Muggy diffs in a t-maxx, why you ask?? because in LST-2 diff cases these things are almost indestructible!
comparison of stock vs muggy, gray VS black (and im sure that 99% of aluminum bulks are cut like the black old school bulks)
any one with the FLM chassis could you please measure the height of you frame braces, im planning to use those but up side down thanks :)
rccna.com
its me
its me's Avatar
12.23.2007, 05:34 PM
rccna.com
cemetery gates
12.23.2007, 07:49 PM
So, what mods are need to do this(to the bulks/diff case)? It looks pretty cool!
Bye
12.23.2007, 09:58 PM
Very interesting, are the muggy diff cases the same as the lst/aftershock cases? These are the real hybrid diffs, parts from all over the place!
its me
its me's Avatar
12.24.2007, 04:44 AM
they are almost the same, difference is different pinion ring gear tooth count.
rccna.com
phildogg
phildogg's Avatar
12.24.2007, 10:21 AM
are these alot stronger than the maxx diffs?
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
12.24.2007, 11:55 AM
phil
Yep, the lst/aftershock/muggy diffs are very similar to std 1/8 scale diffs, 6 gear spiders and you can get TiN coated gears for the lst 43/13 ration, which should help them last. I think my new 20xl hv maxx will use this mod, thanks its me for the great idea!
bdebde
That's All Folks!
bdebde's Avatar
12.24.2007, 11:46 PM
You can also get the ti-ni for the muggy ratio (45/11), just use Mayhem ST gears.
12.24.2007, 11:18 AM
Hmm, that looks very promising- keep us updated dude.
its me
its me's Avatar
12.24.2007, 06:01 PM
here you go George and for any others that have not seen the inside of a LST/muggy/8T diff.
very nice helical cut ring and pinnion
some have asked and yes the diffs are very very strong, my twin motor has yet to kill one yet.
rccna.com
12.24.2007, 06:43 PM
all i can say is zuuuuuurrrrrbbbbbbb......
SpeedAssault
SpeedAssault's Avatar
04.10.2009, 07:23 PM
its me, Did your Cheese fall off your cracker ?
"I'm the jerk " , because like everyone else I ask questions..>
You mean the amazing Losi diff write up that Emaxx_Quebec did on Page 17
http://www.rc-monster.com/forum/show...&postcount=212
So many people asking questions all the way through the thread. I'm just being blunt.
People do say they are strong
Just thought I would let people know there are real Helical gears available.
its me
its me's Avatar
04.10.2009, 07:48 PM
Hmm..... again try it for your self, the gear has a slight helical cut... BTW do some reading on helical cut gears with out runners, I wouldnt want to use a helical cut gear like hot boddies/ kyosho/ because of side load...
Again you edited, emax Quebec like you asked in a PM about posting pics.. I told him sure!! his pics are great along with his info, grinding down the shafts I dont remember doing?
Remember this idea was never tested before, it was a spur of the moment... trial and error... I still cant understand why your getting frustrated, I even answered your PM's and yet you insist to act like a jerk because I didn't tell you in detail exactly what I did.. what more detail do you need about things I did then the pictures!?!?!? The diffs-- All I did was cut some 1/2 PVC and dremeled it to fit, Absolutely nothing special about that.
The a-arms--- I modified the bulks to fit the upper arms, hell I wasnt even sure that I was going to keep it like that so why would I go into detail about that....
Shocks on my twin LST--- its a LST..... I dont think I needed to explain that.
See what im saying? I also never minded you asking questions but did you really need to have a attitude about it?
rccna.com
SpeedAssault
04.10.2009, 11:02 PM
As a 4 wheeler , People always break their 5/29 gears before people break 4/88's
the reason is more tooth contact
Same thing here for the Helical ,more angle provides more contact, more gears evenly distribute the load, not just one tooth at a time.
Not my thread , or would supply name part numbers. It was just an example
Good day
04.10.2009, 11:25 PM
Good day
Helical does have a problem though, it loads the pinion races perpendicular to their rotation. As the helical gear rotates along the spur it is constantly trying to force itself away from the spur. People with high torque setups would have issues with the inner pinion bearing coming apart due to this load. A thrust bearing would be a good item to add, but space is usually limited in that area...
previous post was purely sarcasm BTW...
