Maxxrickard
Maxxrickard's Avatar
04.16.2010, 11:49 AM
I have i tem. But i have to know aprox how fast i can gear the truck and what gearing the motor/ecs/batteries can run.
The speed is not so importent, when everyting runs great Iam happy.and i talk about kph. I havent find any smaller spur and bigger will not fit, so i will use a bigger pinion.
So it just buy pinion 9-15 and try?
SWEDISH FLM MAXX 5s MMM2200
Maxxrickard
04.16.2010, 12:11 PM
My mistake...
Neil helped me but i mixed kpm and mph..
4s lipo = 40mph
5s lipo = 50mph
6s lipo = 60mph
i will calculate "whit Brian" and be back...
Maxxrickard
04.17.2010, 02:32 AM
I have start to build up another maxx for my kids. I will use stockdiffs and wonder what bulkheads is best?
Should i start a new thread for that truck?
George16
Supermaxx
George16's Avatar
04.17.2010, 02:53 AM
GA bulkheads are great.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Maxxrickard
04.17.2010, 03:53 AM
GA??Can i out the stock diff in it?
George16
Supermaxx
George16's Avatar
04.17.2010, 04:46 AM
Great Assembly.
Sure you can.
Revo with OS .18TZ
Maxxrickard
04.17.2010, 06:27 AM
Nice. Thanks, where can i find it? Not at ebay..
Find there website, is the 6061alu okey?
Is it possible to put the stock diff from 3908 in this:http://www.rc-monster.com/proddetail...LM17001&cat=47
04.17.2010, 08:39 AM
Yes, the diffs in the newer ( grey chassis ) emaxxes are all the same, they will fit any standard maxx design bulkheads. The FLM ones are what I use on my Gmaxx- very nice quality.
Maxxrickard
04.17.2010, 09:02 AM
Than i can put it both in the bulkheads and the combobulkheads?Is that right, that FLM has two options for stockdiffs?
04.18.2010, 03:35 PM
Yes, they sell normal bulks and combo bulks for 3905 & 3906 diff gears; I must say though- dont waste your time or money with the combo bulks. Buy either the standard bulks and some complete 3905 diffs from ebay, or buy the Hybrid bulks & some 1/8 ofna/ hotbodies diffs from ebay or Mike. The combos do fix the problem of diff-case flexing, but they dont fix the weaker spider gears or generally poor mesh of the ring & pinion gears ( the teeth dont match up all that well, even when properly meshed ).
Maxxrickard
04.18.2010, 04:28 PM
Think i go with Stock diff and the normal bulks in My kids truck.
I have hybrid and HB diffs in My first truck.
Maxxrickard
04.20.2010, 03:12 PM
this should be a better setup:
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 14.12857 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Rollout: 1.29:1
Total Motor Speed: 40700 RPM
Vehicle Speed: 49.71 mph (79.85 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
04.20.2010, 03:40 PM
That's look cool... but it might be geared a little high for bashing... I would 'personally' go down a tooth or two on the pinion... see the below examples
Other Ratio: 1
Pinion Tooth Count: 11
Total Voltage: 18.5
Motor KV: 2200
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 17.98182 : 1
Rollout: 1.01:1
Vehicle Speed: 39.05 mph (62.74 km/h)... Full charge at 22v - 46.44 mph (74.6 km/h)
Other Ratio: 1
Pinion Tooth Count: 12
Total Voltage: 18.5
Motor KV: 2200
Spur/Pinion Ratio: 3.83 : 1
Total Ratio: 16.48333 : 1
Rollout: 1.11:1
Vehicle Speed: 42.61 mph (68.44 km/h)... Full charge at 22v - 50.67 mph (81.39 km/h)
With smaller pinions, you will still get good top speeds and increased acceleration...
Alien
Maxxrickard
04.20.2010, 03:56 PM
nice thanks.
i think i will go for 12t.
still wait for mikea CD mount...
have anyone used a CD in a FLM truck?
George16
Supermaxx
George16's Avatar
04.20.2010, 05:35 PM
Originally Posted by G-revoRickard View Post
nice thanks.
I used a CD in my Gmaxx truck.
Revo with OS .18TZ
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
