GriffinRU
02.09.2008, 05:05 PM
Originally Posted by Bernie Wolfard View Post
Please do not solder on the circuit board as it voids the warranty. Before you all post things like "I am a pro solderer" and "I have soldered on circuit boards all my life and really, really, really know what I am doing" consider this. We use high temperature, lead free solder with special flux to enable us to sell our products into the European Union. This solder and flux is not readily available. The circuit boards are heavy copper and conduct heat very well. The problems these create are that standard lead based solder does not mix well with our solder and will create a cold joint. The amount of heat it takes to flow our solder is conducted though the circuit board to the point where parts will loosen or fall off the other side. It takes special training and equipment to reliable solder onto a Castle Creations circuit board without creating problems. Because of these issues, we do not make exceptions to the rule that if you solder on the circuit board the warranty is void.
If you really feel you need to solder directly onto a Castle Creations circuit board and later have problems the saving grace is it only costs about one third to one half the cost of a new ESC to have it replaced. Check the out of warranty replacement costs on the ‘Support’ tab on our website, www.castlecreations.com.
Bernie
As Serum said welcome to RoHS world :)
But you can suck it clean from PCB and solder back with whatever solder and flux you have, right?
P.S. But no matter what warranty void!!!
02.12.2008, 10:49 AM
Eek I didn't know this either - I'm a self confessed lousey solderer who was it appears v lucky!
pipeous
5th Scale Guy
pipeous's Avatar
02.12.2008, 12:09 PM
to solder my caps on, I stripped the wires just above the pcb and tinned and soldered the wires there. a little liquid electrical tape after to seal it back up. I use a big arse soldering gun to solder. I am too impatient for the pencil to heat up. it's not practical for soldering small things, though my bud that makes electronic stuff laughs at some of the small joints I have gotten soldered with such a big gun... lots of practice I guess hehe. I dig holding a trigger for a few seconds and presto, hot enough to solder even battery bars. if I have to solder a pcb I will use the pencil, but most times the gun works for me.
Bernie Wolfard
Clinically Inane
Bernie Wolfard's Avatar
02.12.2008, 01:30 PM
Putting caps on the actual wires close to the ESC is a good way to do it, but I still don't see the reason for adding capacitance. A well-designed ESC won't benefit from it, it just adds expense and effort. If other brands of ESCS benefit from it seems to say something about their design.
A soldering gun is not appropriate for electronics work. There is 120 volts going through the tip when on which can quickly create a disaster with electronic circuits.
Bernie
02.12.2008, 01:40 PM
Throughout my testing of the mm, it seems to lower the operating temperatue of the esc. I am running 4s lipo, and outside of the spec of the esc. All of mine are working fine and stay cooler with the added capacitors.
GriffinRU
02.12.2008, 06:35 PM
Bernie
MambaMax is well-designed ESC when you use it below 3S LiPo/300 Watts.
But when you start pushing limits, then new caps and extra heatsinking comes to play.
-plus couple other things here and there.
Bernie Wolfard
Clinically Inane
02.14.2008, 03:24 PM
The cell limit for the Mamba Max is based on the Kv of the motors we include with the system, not the Mamba max ESC. Simply multipy the motor Kv by the pack voltage. If it is over 65,000 the motor will spin apart. With lower Kv motors the ESC has no problem with higher voltage, up to 5s lipo. The ESC is about a 100 amp ESC. 100 amps X 18.5 volts = 1850 watts. The issue is you must have batteries capable of 100 amps continuous output. Many battery companies C rating would lead you to believe they can do this, few deliver on the promise. We recommend having at lease 20% more battery capacity than you think you will need to avoid problems. Also only buy lipos from reputable companies, most of which are not common in the RC-Car world.
If you have adequate batteries you don't need extra capacitance and if you have inadequate batteries extra caps won't help you.
The amount of power it takes to move mass goes up by the square of the mass. While the Max system with a Max motor used withing spec is capable of 1000 watts (11.1 volts X 90 amps) and is capable, with a lower Kv motor and more voltage of about 1850 watts. However, this is not enough to move the weight of a Monster truck or 1/8th scale conversion reliably. In these systems the Mamba Max ESC is a $130 fuse. When you hit the throttle hard on a hot 1/10th scale the amps will spike over 500 amps. The spike with a heavier car is a potential ESC killer. Capacitance has no affect on these spikes. BTW, the amp spikes in our 1/18th scale systems are over 150!
Bernie
Supervisor, Product Support
02.14.2008, 07:13 PM
So in a light crt .5 - 5s is ok? Cool!
MetalMan
MetalMan's Avatar
02.14.2008, 10:40 PM
Bernie
You sure? In physics classes they teach us that kinetic energy (KE) is equal to the mass (m) times the square of velocity (v). You can set KE equal to work (W), and power (P) equals W/time (t). So, P = (mv^2)/(2t). That means that in terms of theoretical power requirements (not accounting for friction), an 8lb truck will use only twice as much energy at the same speed and over the same time interval as a 4lb truck. Power required for acceleration is a different thing, obviously.
Serum
Serum's Avatar
02.20.2008, 12:57 PM
It should take about 33 percent more energy to go 10 percent faster.
GriffinRU
02.24.2008, 03:28 PM
Bernie
Thank you,
Useless..., I've sent you PM hoping to keep it private, but here we go. Mambamax is perfect and you guys have bad batteries and do not know how it works...
Wake up, you are sales and support fellow, while couple guys here actually do now how it works and can design and improve existing ESC's. You might have wrong image about who you are talking to.
Sorry for harsh post,
Artur
P.S. I won't even comment power requirements and formulas, i.e. physics. I am not sure about your CV. But explain me what the cap is actually for in the ESC, besides charging and discharging :) You talking about in-rush currents and so, but looks like you have no idea, like I can't see how the cap can discharge in the circuit while being attached to good battery, playing dumb of course...
Also, have you even consider about efficiency of your ESC at half throttle, while pulling 1850W? Ok, maybe half...
What is the power capacity of your heatsink on ESC?
