hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
07.19.2008, 02:36 PM
I have the TrueRc 15c 2 cell 8000's also. They are a tight fit, but still....they fit. Great for long runtime on 4 cell set-up.
I found these recently;
I was thinking 2 of these run in a series for a 6 cell set-up.
http://www.hobbycity.com/hobbycity/s...idProduct=7240
From the website;
The solid C rating and long life put the ZIPPY-Rs performance and value for money combination in a category of its own.
Spec.
Minimum Capacity: 4800mAh
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 25C (Minimum)
Peak Discharge (10sec): 35C
Pack Weight: 395g
Pack Size: 170x25x45mm
Charge Plug: JST-XH
__________________________________________________ _____
at 170mm long it may be a tight fit running the wires, but it should work.
4800X25/1000=120 Amps Constant --- 4800X35/1000=168 Amps Burst
enough for even the most demanding motors (neu)
not bad for under $60 a pop.
As for the e-revo itself... I did some measuring;
you can't see it good, but the measurement on the right is 10mm. So you have a total of 180mm in length, but the first and last 10mm only have 20mm of height.
Those batteries SHOULD work, but it will be close...
tell me what you think
~jarrad
t-maxxracer32
t-maxxracer32's Avatar
07.19.2008, 03:32 PM
they would be extremely tight. not sure if id want to try it out only to find that they wont work.
if you end up getting them let me know how it goes!
Jan Donga
07.21.2008, 01:11 PM
I have dropped my eye on the flightpower 3s 5000mah and neuenergy 3s 5000mah. But i still don't know if they would fit the battery compartment. Do you guys already know with ones will fit for sure?
E-Revo
Spektrum DX3R
Tekno Neu 1515 1Y F
4s 8000mAh
MMM (when it comes in)
07.21.2008, 08:22 PM
Hoov updated his picture:
Hopefully that helps when comparing dimensions of lipos.
azjc
07.22.2008, 02:36 AM
these are the dimensions off of Towers web site
167 x 48 x 27mm
they can fit...maybe a little tight on the length but a small challenge never hurt anyone.......
