rchippie
rchippie's Avatar
02.27.2009, 11:13 PM
What is with the bent link connecting the two FR wheels ?.
REAL MEN RUN BRUSHLESS
12.23.2008, 11:56 PM
Hi Linc - Yeah I was having issues with the FLM chassis when I moved the links inside - As you can just tell from the last pic I drilled some extra holes in the chassis to move the lower links further forward and this brought everything back into line...
Cheers.
02.27.2009, 11:25 PM
Supposed to be a high clearance steering link but worked like C**P...
This is it now... with CVDs, derelin trans mount, RRP gears and slipper kit.. Oh and some bling...
Ps I had to drill the extra holes for the top links in the the chassis...
rchippie
rchippie's Avatar
02.27.2009, 11:28 PM
I see you went back to a straight link . The lights look pretty cool . Why did you have to drill more holes ?. Also if i get this chassis what tranny mount & skid plate combo do i get ?.
02.27.2009, 11:35 PM
I went for this:
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_975wt_1165
I did the mod to move the top links inside and further back - without drilling the extra holes the front and rear axles were tilted too far forward
rchippie
rchippie's Avatar
02.27.2009, 11:43 PM
I went for this:
Whats different about that one versus the stock one ?. Is the mod really needed or just personal preference ?.
02.27.2009, 11:54 PM
mod works well and derelin is slippy
rchippie
rchippie's Avatar
02.28.2009, 12:04 AM
I thought it said it was aluminum . Do you have to do the mod ,to get the truck to work right ?.
02.28.2009, 12:14 AM
Check tony's article out
http://www.stampedeproject.com/Axial-Tuning2/
rchippie
rchippie's Avatar
02.28.2009, 12:34 AM
thank's . I thought the FLM chassis had the upper links all ready on the inside, with no mods .
rchippie
rchippie's Avatar
03.04.2009, 11:30 PM
Chris everything for my FLM crawler has been orderd & should be here by friday . My skid plate showed up today & my shocks will be here friday. How do you like the lipo on the FR axel ?. I dont know if im comfortable doing thaat .
03.04.2009, 11:41 PM
sweet - i'm still awaiting the links from mike but everything else is done...
I'm not sure i'd like to run lipos on the front which is why i opted for a123 for my crawler - that way i don't have to worry about it but still get the benefits.
I bought some vpx packs cheap - iirc 30 for 3 packs and make a 2x3s1p 1100 packs for a 3s2p 2200 setup... i also have a 1s2p 2300 setup from a couple of spare cells.
rchippie
rchippie's Avatar
03.05.2009, 12:33 AM
I have two trakpower 3s 1600 lipo's for power . I could make a nice cover for them out of kydex plastic to protect them if i decide to mount them on the FR axle at a latter date . I most likly wont get a dig unit for a little while . I just saw on tower that the low cg battery plate does not have the 4 link mod on it . So i guess i would have to get a plate to copy & put the 4 link mod in it . But it is a little pricy $26.00 for that plate is a lot .
03.04.2009, 11:43 PM
note if you decide to run a dig you may have to run some mods on the spc plate - i'll get some pics for you at the w/e or when mike gets me the links ;)
03.05.2009, 07:49 AM
check out tcscrawlers plates they are pretty cheap...
